Results 1 to 5 of 5
    Sep 2002
    2,639
    3 units out one location
    Unit one 3hp walk in, burnt contractor coil,Unit two 5HP produce case line up,off on oil pressure.Unit 3 Carrier 48TM009 RTU,burnt trans and IGC board.Voltage readings 197,190,182 One of the phases to ground 80v,only slightly better in the basement.So we call sparkey,I go for coffee.When I come back much of the lights in the store are going on and off Con Edison gets called,I shut down all my three phase stuff.They pull the man hole cover in the street,one phase wire burnt to a crisp ,another smoking.I got to say these guys did some job,they did a resplice live in less than two hours! Readings now 217,215,212!
    Feb 2009
    Tallahassee, FL
    5,821
    That's intense work.
    17,000
    It is.
    Procedures and protection.
    Sep 2002
    2,639
    Quote Originally Posted by SBKold View Post
    Yea,The coffee part was bad,It's a fight to give up the doughnuts!
    Jun 2010
    Jackson, MS
    78
    You did a really smart thing by getting your equipment off-line ASAP. Saved somebody a bunch of money. Seen several 3-phase motors cooked when a phase goes low or goes away. People should put phase monitors on such things - they rarely do.
    Dave E
