Results 1 to 13 of 17
    Nov 2011
    St. Louis
    3,741
    Piggyback breaker?
    As in a condo complex with the outside units fed via a bank of larger breakers just below the meter in the garage. Supposedly the one on there now is a 40/40 "piggyback" and I need to change it to a 40/20.
    What's the story with these? Does one side of the breaker feed the other? Another case where I'll have to do some walkin' back and forth as right now the installers don't know which side of the breaker feeds the disconnect as they are both 40s. Got a 50/50 shot on the first try, though...
    Why would there be a need for a piggyback? Space contraints? Why not just use skinnys?
    2,319
    Can you take some pics? Ide like to see this.
    Nov 2011
    St. Louis
    3,741
    Quote Originally Posted by Core_d View Post
    Uh...that doesn't inspire confidence
    Attached Images Attached Images
    2,319
    Piggyback breaker?
    Where can i get that in poster size?
    Aug 2012
    Gainesville, FL
    325
    Piggyback is two single pole breakers fed from a common bus clip in a single slot case. I've never seen them with two different values. You may have to combine some household circuits together onto 20/20 (or 15/15) to make room for the one you need. They're pretty common in the QO and HOM panels. Beats the heck out of putting in a bigger panel or a sub panel.
    http://www.homedepot.com/p/Square-D-by-Schneider-Electric-QO-2-20-Amp-Single-Pole-Tandem-Circuit-Breaker-QOT2020CP/100021761#.Ud4jPcu9KK0
    Nov 2011
    St. Louis
    3,741
    Well...I don't know if our guys are using the term correctly. I also heard the term quad bank or quad pack...quad something.
    I don't understand why they did it like this, but here it is. Essentially it's just two single pole skinny breakers paired up per 240 load to catch both legs. You then have to connect them so if one trips they both trip. Simple as that. You'll note the middle two have a clip that fits over the throws, and the outer two are connected by a bracket with nipples that fit into a hole in the side of the throw. We're more used to seeing a bar or pin that connects the throws.
    For the life of me, I can't understand why two regular fat breakers side by side would accomplish the same goal much easier. The load center wasn't built to accomodate any more breakers anyway, fat or skinny.
    19,822
    Am I right in thinking that I see only the two center breakers in use, one on each line?
    2,319
    Piggyback breaker?
    Hmm dont see a switch at all? Looks like a connection to the hot bus(s). Keep us posted, far beyond me.
    Nov 2011
    St. Louis
    3,741
    Nah...I took the picture before I buttoned it back up so you could see the nipple on the left that fit's into the left most breaker.
    They are four skinny breakers, two in the middle for an undetermined load (range) and the outer two for condenser. It's resolved and works, and I see how...just not why?
    2,319
    Piggyback breaker?
    So they are not directly off the bus? Call an electrician.
    2,319
    Any update on the piggybacks?
    Nov 2011
    St. Louis
    3,741
    Hu...what? Sorry - I had put this one to bed.
    We basically have four skinny single pole breakers behaving as two double poles; with bracket-type whachamahickies ensuring that if one pole trips, the other will as well to ensure that improper voltage will not be fed to the device and someone will not be harmed by the remaining leg of power.
    I'm just not sure of why it was done in this manner way back then (about 40 years) and suspect it was simply for versatilty. It's a condo situation with the 120v 15 and 20 amp breakers in the dwelling and the 208-230 2 ploes in the garage below.
    If there are any lingering questions I'll send the picture to my electrician buddy around the corner and have him explain...?
    2,319
    That about clears it up
