Disconnect breakers
Results 1 to 13 of 18
    Nov 2011
    St. Louis
    3,166
    Disconnect breakers
    See attached. Are these breakers that you find in outdoor disconnects just regular breakers that would fit in a panel? Like if I say gimme a GE fat 2 pole 40, a Federal Pacific Stab Lok 2 pole 30 or a Zinsco 25 etc?
    Or are they a special bread made for outdoors with a different mounting application?
    Attached Images Attached Images
    Anderson, South Carolina, United States
    6,214
    Cant open the pic on my phone but The ones I see are square d QO240 breakers but the ones that come in them aren't actually a breaker just a switch. You can put a QO in them.
    Feb 2009
    Tallahassee, FL
    5,973
    That one looks like a square d homeline which also is seimens/fat ge compliant.
    Nov 2011
    St. Louis
    3,166
    Quote Originally Posted by SBKold View Post
    So how are they mounted? I don't see a lip or busbar to bite into...?
    Feb 2009
    Tallahassee, FL
    5,973
    Should be a lip it catches onto bottom
    Jun 2002
    south jersey
    1,096
    It's there behind the breaker on bottom. Just pull down and away and it should pull off. With power disconnected of course.
    You need to put the phone down and get back to work!
    May 2011
    Oklahoma
    362
    Should be able to fit a cutler hammer BR in there too.
    Dec 2002
    SouthEast NC ICW & Piedmont Foothills
    7,635
    might want to find out if Sq D has changed their attitude toward putting a homeline in a ITE panel
    It`s better to be silent and thought the fool; than speak and remove all doubt.
    17,721
    ITE panels accept Seimens breakers.
    Nov 2011
    St. Louis
    3,166
    Quote Originally Posted by jnsrose View Post
    Uh oh...I never turn off power when changing breakers. Am I being stupid? Or do you mean because it would be easy to kill the circuit inside?
    BTW, the issue here was the inspector seeing the 50A breaker outside on a 40 max unit. I suspect the installers, confronted with two old square D panels with both cartridge and screw type fuses and a blade type disconnect labeled "furnace" inside; meant to track it all down at some point and then let it get away from them. It turned out to be the blade disconnect, threw a couple 40s in and all is good.
    Well...to be honest I never changed that type of fuse before and didn't know which was hot, top or bottom. Suddenly I'm a rookie again and wondering if I'm about to make a fatal mistake, simply because it's old and I've never seen one before. I completely forgot about the NCVD that was right below my nose in my shirt pocket. In the end I slammed them in with insulated channel locks while bracing for a small arc flash or inadvertant fumble to ground...
    Should I own a fuse puller?
    6,214
    Quote Originally Posted by hurtinhvac View Post
    You've got channel locks right.... I've got a fuse puller somewhere but its never handy when I need to pull a fuse my channel locks are always close by.
    May 2011
    Oklahoma
    362
    ...while bracing for a small arc flash or inadvertant fumble to ground...
    Yes.
    17,721
    It is much easier to use a fuse puller. Fitting the channelock jaws into position can be a real pain in many fuse holders.
    I carry a puller with me everywhere. Too many 460 v 3 phase boxes on roofs...
