Results 1 to 10 of 10
    STONE MOUNTAIN GA
    1
    Single phase and Three phase motors
    im a college student studying HVAC, and I was really trying to understand the difference between single phase and three phase motors in the hvac industry
    Aug 2006
    Mixing oil and fire with a big spoon.
    4,649
    that is a very loaded question. basically, a single phase motor uses 2 lines of incoming power and a three phase motor uses 3 lines of incoming power.
    a single phase motor is usually used for low horsepower applications where as 3 phase motors are used for larger horsepower applications.
    "By Grapthars Hammer....what a savings." Galaxy Quest
    Mar 2009
    Mid-Mo
    3,596
    Were you looking for something more specific? Jay gave a good answer for how vague your question was.
    2,359
    3phase is more efficient although initial cost is more. This video may help http://m.youtube.com/watch?v=07uXnc1C5CA
    Quote Originally Posted by RIEIO View Post
    The motor used is matched to the building power available, so a commercial unit installed where 3-phase power is available will contain 3-phase motors, while a residential unit will have single phase motors.
    The big difference between the two motors is that 3-phase motors use the phase rotation of the incoming power itself to create the rotating magnetic field, while single phase motors cannot. They must use an additional component (such as a capacitor) to create the necessary phase shift for starting, and in some cases running as well. This creates additional complexity and points of possible failure for the single-phase motor.
    Very cool old video btw core_d.
    Jan 2010
    7,635
    Jun 2011
    398
    Also, 3phase motors have poles mechanically separated by 120 degrees, which coincides with the phase angle offset of 120 degrees per phase. 3 phase motors do not have starting aids (relays and caps) because the starting torque is so much greater than single phase.
    Sent from my HTC One S using Tapatalk 2
    Winter Haven, FL
    4,380
    Quote Originally Posted by timtanguay View Post
    Actually they do have relay systems to start them. Look up wye delta starter.
    Nov 2004
    Anchorage Alaska / Seattle WA
    205
    Just hang on Rieo... If your in college they will explain that to you - it might be coming later in the course. It's been my experience that college explains things to such a depth that alot of it is useless. So if they don't explain that basic difference in an ac/refer education that you are paying thousands of dollars for... sue the crap out of them and get your money back bud...
    2,359
    Quote Originally Posted by genman View Post
    Genmen, good to see in the forum. You have dug up every thread I have been a part of in the electrical forum. Perhaps you could start your own thread either learning or teaching.
    Hope to see you in the future.
