Results 1 to 3 of 3
    GE 5KSP39FGW452S Condenser Fan Motor
    Hello.
    My GE 5KSP39FGW452S condenser fan motor has vents on each end, but, is a 230 volts AC, shaded-pole model. Will it be ok if rain blows on it?
    I was wondering since it doesn't appear to have any uninsulated electrical parts which could be damaged by water.
    Aug 2006
    Mixing oil and fire with a big spoon.
    4,017
    how is the motor mounted? shaft up? shaft down? shaft horizontal?
    It's tube brushing season...93% done (39.35 miles of tubing)...only 1,242 tubes to go!
    Original member of the Raccoon Brotherhood.
    EVERYTHING IS AWESOME!!!
    17,031
    Quote Originally Posted by Tetracomm View Post
    Hello.
    If it IS a "condenser fan motor," then it should be RATED for outdoor conditions.
    I suspect you have a BLOWER motor.
    The GE site should have your answer.
