Results 1 to 12 of 12
    May 2000
    Rochester, NY, USA
    14,996
    Small wind generators < than 1000 watts
    anyone have any experience with wind generators for weekend/vacation cabins
    I have an off grid cabin that I power with solar panels, but I want to install a wind generator that's less than 1000 watts.
    anyone know which small generators are good, which ones are not-so-good
    I LOVE SLEEP
    It's like being dead, but without the commitment
    Sep 2005
    Atlanta GA area
    24,891
    There was some information on wind generators in a Northern Tool catalogue a while back... forgot the rest. Might check with them.
    GA-HVAC-Tech
    Quality work at a fair price with excellent customer service!
    Romans Ch's 5-6-7-8
    2 Chronicles 7:14
    May 2000
    Rochester, NY, USA
    14,996
    Thanx, Im trying to find a consumer report type source for which small wind generators are the most reliable.
    I LOVE SLEEP
    Jan 2009
    Keokuk, IA
    5,520
    The trick is getting the generation, stoprage and inverters sized for both peak and your largest sustained loads. Pay attention to power at more average wind speeds not the peak. Ypu migth still consider being able to tie in a portable generator like a little 2000watt honda if needed.
    Also look at your loads and see what you can trim. Buying some led light bulbs may be cheaper than upsizing generation. You might power larger loads like a microwave off a portble generator like a 2000 watt honda.
    Sent from my SGPT12 using Tapatalk 2
    May 2000
    Rochester, NY, USA
    14,996
    here's what I got, a 1000 ft² cabin that is off grid. Im running the lights on 410 watts of Solar panels, with two 6volt Golf cart batteries in series=12volt output thru a 1500 watt inverter.
    The refrigerator is a old Servel(best refer on the planet), propane fired and so is the stove
    I have a 4000watt Listor diesel Generator to heat water in an electric HWT. I also have a 8500watt gas generator for winter use and to back up the diesel.
    What I want is a Wind generator so when I don't have sun (and at night) Im still charging batteries and to run a solar refrigerator<furture> . The wind generator will either be locked down or disassembled in the winter.
    This place only gets used on weekends from March thru November. and occasionally on a weekend or two during winter months.
    In the winter everything is disconnected except the solar panels and batteries. the charge controller will shut off the panels when the batteries reach 14.5v
    Now does anyone ever have any information on which wind generators are the best, in the 600-to-800watt range. I want a cut-in speed around 5mph. I don't care what wind speed it starts turning, I want cut-in speed
    I LOVE SLEEP
    Jan 2009
    Keokuk, IA
    5,520
    Id switch the water heater to a tankless propane unit. Wind just like solar will lean on the batteries. Typically wind drops off at night sincd its also solar driven.
    While doing so searching, I found this. http://www.solacity.com/SmallWindTruth.htm
    Cut I. Speed seem to be 5 to 8 mph, but output is fractional at that point.
    They are basocally saying that the money if better spent with more batteries and solar. Wind is too inconsistent as a primary source. You get sunlog eveyday even if cloudy. In mid summer you can goes days without wind over 5mph.
    Id do some more research first. Consider what heigth and under what conditions it produces rated output.
    Sort of like a ac system, in texas on a 105f day, a 3 ton unit is not producing 3 tons.
    May 2000
    Rochester, NY, USA
    14,996
    I understand what your saying, This is a weekend/hunting camp so the batteries have Monday thru Thursday to charge up (I try to take Fridays off in the summer~~~it doesn't always work that way, but I try)
    My cabin is on a Lake(400ft of frontage) During the summer the roof gets anywhere from 6 to 12 hours of light (I didn't say sun) per day. Its the spring and fall I want the wind generator. We get a decent breeze at night, when the days are shorter.
    Right now I have 120watts (on the roof) charging the two 6V golf cart batteries, I have three more 145watt panels in the garage that will go up the spring for a total of 555watt.
    I have a Morningstar 45amp charge controller in the garage that will replace the 10amp unit Im using now. (The Morningstar controllers can be "stacked" in parallel, so i can add as much solar or wind as I want)
    I also need to get a couple of six volt, 1000+CCA diesel truck batteries to replace the golf cart batteries. The new diesel truck batteries are designed to run a 12v truck a/c all night. Trucks can no longer idle for more than 5 min. So they designed an a/c and batteries that will run most of the night. I can also run the batteries in series/parallel to increase amps output.
    I guess my goal is to eventually get enough solar/wind generation to run a Mini-split heat pump. all I need is a 1½ ton system. I just need to figure total load with a mini-split
    I LOVE SLEEP
    Is your Morningstar controller an MPPT (max power tracking) type? Most MPPT controllers can only be used for photovoltaic, not wind.
    May 2000
    Rochester, NY, USA
    14,996
    Quote Originally Posted by DDC_Dan View Post
    I think you maybe right, I just got it and have not read up on it. A friend recommended it, so thats what I got.
    Not many people know about or understand wind generation, at least micro-wind. there seems to be a boat load of mis-information out there, thats why I was hoping someone here had some experience with them
    I LOVE SLEEP
    Quote Originally Posted by jmac00 View Post
    True. In my case, I live in an area (sunny Phoenix, AZ) where wind generation would be completely useless, but solar is very attractive. Hope you find some good info.
    May 2000
    Rochester, NY, USA
    14,996
    thanx
    I LOVE SLEEP
    Mar 2014
    Altoona, Pennsylvania
    308
    Hi,
    I was on the road for years building wind farms. GE was the one I liked the most. I do believe they make a residential one. There are other ones out there too.
